CW 10   -  M54418TWR - linux:  compile error help
574件の閲覧回数
francois_boucha
code:
const struct can_frame *cf = (struct can_frame *)skb->data;
Error:
dereferencing pointer to incomplete type
not sure why I gor this error any idea?
thanks
FB
タグ(1)
382件の閲覧回数
francois_boucha
the full code is:
/* Drop a given socketbuffer if it does not contain a valid CAN frame. */static inline int can_dropped_invalid_skb (struct net_device *dev, struct sk_buff *skb){    const struct can_frame *cf = (struct can_frame *)skb->data;    if (unlikely(skb->len != sizeof(*cf) || cf->can_dlc > 8)) {        kfree_skb(skb);        dev->stats.tx_dropped++;        return 1;    }    return 0;}
There is the same error here also:
And this warning also:
'struct net_device' declared inside parameter list    dev.h    can_llvl 150 error/Sources/header/linux/can    line 62    C/C++ Problem
Is it related?
regards
