Warnings about macros in project settings - how to improve?
搜索替代
1,647 次查看
mjbcswitzerland
Specialist V
Hi All
When moving projects created with CW10.2 to CW10.5 there are a warning when importing:
"References to the ${workspace_loc:<resource>} macro were found in the project settings. Using this macro could cause unexpected errors when the resource is not open or available in the workspace. Using the ${ProjDirPath} macro is preferable."
- followed by a list of project or target references.
I wanted to clean up the project so that these warning are no longer shown (otherwise other users of the projects report that there must be a problem with them) but couldn't find any such macros used in path variables or elsewhere.
Does anyone know what can be done to adjust a project accordingly?
Mark
标记 (1)
1,285 次查看
BlackNight
Hi Mark,
I would check the compiler settings (include search paths, etc) where these kind of macros might be used.
Otherwise: open the .project and .cproject files in a text editor and search for that macro: then either change it in the file directly, or this gives you a hint where in the settings that macro is used.
I hope this helps.
1,285 次查看
Jorge_Gonzalez
Hello Mark:
Did you look at the include directories?
Go to Project -> Properties -> C/C++ General -> Paths and Symbols, and verify that none of the include directories for assembly or C languages is pointing to the workspace.
Regards!
Jorge Gonzalez
1,286 次查看
BlackNight
Hi Mark,
I hope this helps.
1,285 次查看
mjbcswitzerland
Specialist V
Hi Eric
Thanks - it was indeed in the compiler include path.
In each project I modified the include path from
"${workspace_loc:/Project/Applications/Target}"
to
"${ProjDirPath}/Applications/Target"
and then CW was happy again.
Mark
