PID constants
PID constants
842件の閲覧回数
binukannur
Hai,
  Iam using HCS08 and codewarrior studio.    I implemented a PID algorithm for a generator speed control by  valve control  using stepper motor. Here Iam measuring rpm of generator with hall effect  sensor as  a feedback.
It works fine, but in this algorithm I changed my Kp,Ki,Kd constants in different conditions. ie nearest of setpoint I changed these constants to get fine values and if there is a big difference changed to get large error value.
My question is , can i change PID constants in running condition? Is it favourable ?
3 返答(返信)
531件の閲覧回数
trytohelp
To investigate the problem we need more info.
What is the development tool version you're using ?
Please can you provide us to code or example code  showing the behavior ?
Pascal
Freescale Technical Support
531件の閲覧回数
binukannur
Hai,
      Iam using   Code Warrior Development studio V.10.6, and controller MC9s08DZ128.
Here is the bit of code we want to investgate.
  if(count > (rpm_setpoint-4) && count <(rpm_setpoint+4))//fine tune PID constants when setpoint reached
      PID=PID_Compute(0.5,0.2,0.01,1,-5,5);//kp, ki, kd, dt(time intervell) , outmin, outmax
     else
     PID=PID_Compute(1,0.5,0.25,1,-20,20);//kp,ki,kd,dt,outmin,outmax
count  -- it is the feedback value .here it is generator RPM input
rpm_setpoint  --- set point
PID_Compute---- PID function
PID----  it is the output
outmin,outmax  -- Iterm minimum and max value.
In the first loop , PID value is small and in the second loop PID value is high compared to first.
So if there is a large error the second loop will run and faster the adjustments.
531件の閲覧回数
kef2
Senior Contributor IV
What do you do to PID integral when you change PID constants? If close to the right anti windup control is implemented, then at least you should recalculate PID integral every time you change PID constants. IMO it is totally wrong to change PID constants (constants!) on the flight.
