Is there a PC-Lint (v9) compiler configuration file that is suitable for use (with little or no modification) with CodeWarrior for MCU (v10.6) projects that use the ARM toolchain (compiler = mcccarm)?
Thank you.
Hi Brandon,
and maybe https://mcuoneclipse.com/2012/04/10/linting-without-a-plugin/
I hope this helps,
Erich
