Link Errors
Link Errors
1,110 次查看
sebikoo
Hello.
Recently, I received a project file to
analyze it. This prject is mainly generated by Processor expert.
- CW IDE Version: 4.5
- Chip: MC9S12XDP512
However, When making,
it causes so many link errors,
and warnings. As I am unfortunately still not familiar with
CW IDE and Freescale chips, it has been
so difficult for me with those errors.
Thus, I here attach a whole project file
to be analyzed by gurus.
This project is really get me depressed.
sebikoo
Message Edited by sebikoo on 2008-11-23 10:13 PM
Train1.zip
Message Edited by t.dowe on 2009-10-22 09:17 AM
标记 (1)
387 次查看
CrasyCat
Specialist III
Hello
Here I would advise you to contact whoever did generate that project. The problem is not related to  CodeWarrior or Processor Expert, but with the project you are using.
I do not understand what the person, who has generated the project did try to achieve here, but modifying
ProcessorExpert generated code is a very bad idea.
Also merging content from several modules created by ProcessorExpert is a very bad idea.
There are a lot of functions which are implemented in 2 modules (for some reasons).
I would recommend you to remove the file IO_Ports.c from the project, also remove file rs485_rs232.c from the project.
Also for some reason, content from several modules have been merged in events.c. I do not understand what is the reasoning behind that.
So I would suggest you to contact the creator of the project and ask him to provide a fixed version of his project.
CrasyCat
388 次查看
CrasyCat
Specialist III
Hello
CrasyCat
