How can I disable "dead code stripping" in CodeWarrior?
775 次查看
lukekim
Hello
I want to know how I can disable "dead code stripping" in CodeWarrior or ".lcf" file.
(I want all unused symbols, functions and variables, to be included in the elf image file.)
I found "KEEP" directive that I can use in .lcf file.
But, the indicative does not work correctly.
- .text() : { KEEP(*(.text)) }
My development environment:
- Window 7
- CodeWarrior for MCU Version 11.0
- MPC5674F
Thanks.
610 次查看
stanish
Hi Luke,
Please try to use
 FORCEACTIVE { symbol1, symbol2,...}
 which works on symbol level
or
 KEEP_SECTION { section1, section2...}
section level.
Hope it helps.
Stan
610 次查看
lukekim
Hi Stan,
Thanks for your reply.
I have tried the following, but there's an error.
MPC5674F_FLASH.lcf
==> added : KEEP_SECTION {.text } // I added this code at line 130.
==> error message : '=' expected in command file at line '130'
Please let me know how to use it correctly.
Build ID of CodeWarrior for MCU is 170926.
FORCEFILES{} does not operate correctly also.
Thanks.
