Is anyone able to help out with a couple of questions i have already posted to this forum? I have a project due in a week and codewarrior just started to not communicate with my device. Don't understand the issue would like some insight.
解決済! 解決策の投稿を見る。
Hello
Did you consider submitting a service request through our on-line support web page?
You should be able to get faster response this way.
Click here to submit a service request.
In order to save time make sure to
- log 1 problem per service request
- attach a project reproducing the trouble.
- specify which version of the tool chain you are using.
To retrieve that info for version < 10.0:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
To retrieve that info for version > 10.0:
- Start CodeWarrior
- Select Help -> About CodeWarrior Development Studio
- The version number and build number we need are the one specified under "Installed Products"
CrasyCat
Hello
- Start CodeWarrior
- Start CodeWarrior
CrasyCat
