Crazy function for local scope: help!
1,836 次查看
cicciounico
I use MC9S08LC36.
I have make a function defined in funcs.h :
void CaricoOre(unsigned char );
I use this function and I pass it a global var defined in ram.h with:
#ifdef _MAIN_C
   #define g_var
#else
   #define g_var extern
#endif
g_var unsigned char ore;
My problem is: when I call My function, the var passed is 0 but insiede the function is random value!!
Why?
The screen shot: call function
http://ciccioamore.altervista.org/1.jpg
Inside the function:
http://ciccioamore.altervista.org/2.jpg
标记 (1)
724 次查看
cicciounico
YUUuuuuuuuuuu!   :smileyhappy:
Thanks: I have insert option: -Wpd
and the compiler have alert me with warnig!
Missing : #include funcs.h     :smileysurprised:
thanks again!   :smileyhappy:
724 次查看
Navidad
I am no debugger expert, but what happens here is that the parameter is passed through a register (namely A), and not on the stack. Check the value of the A register (the register view is not included in you screenshots). I would expect it to be 0. Note that for functions with a fixed number of arguments and when the size of the last argument is one byte, the compiler will always pass this last argument through a A register (this behavior is documented in the compiler manual in this section: "Calling Protocol and Conventions" ).
Navidad
724 次查看
CrasyCat
Specialist III
Hello
It would be worthwhile checking if you have a prototype of function Caricoure in module where ShowLCD is implemented.
In order to figure that out, can you please add the option -Wpd to your compiler command line? If you get an error message that means you are invoking the function, but there is no prototype for it.
Please add a prototype for the function before you call it.
If this does not help, I would recommend you to submit a service request for that.
Click here to submit a service request.
Make sure to attach a reproducible project and installed product information to the service request.
To generate the required information:
- Start CodeWarrior
- Open the project
- Select "Help" -> "Pack and Go" and follow instructions on the screen.
Attach the generated .zip file to the SR.
CrasyCat
725 次查看
cicciounico
