I found Cyclone MAX in Code Warrior to use as a debugger, not Cyclone FX.Has anyone tried using Cyclone FX as a debugger?Thanks
Solved! Go to Solution.
Hi smecolive,
According to P&E,
The Cyclone FX is able to debug K60FN1M0 target within CW11 when using the PE Micro plug-in. The PEMicro driver should be included when installing CW11.
Hope this helps,
Jun Zhang
Hi smecolive,
According to P&E,
Hope this helps,
Jun Zhang
