Build a library with Codewarrior 10.6 and change compiler
次の代わりに検索
1,119件の閲覧回数
dev25
I am quite new at Codewarrior, and I have two problems at the moment :
1/
I have to port the eGui files (driver and D4D files) into a c++ code warrior project for my k60. I have thought about building first a library with this eGui files (indeed the c++ compiler report many problems when I try to build the eGui files)
But I didn't find in the settings of my project how to build a library in CW 10.6, as my project is based on a MQX 4.1 Project (File -> new -> MQX 4.1 Project). My questions are :
- What are the differences between MQX 4.1 project, MQX-Lite project and Bareboard project ?
- How can I compile the eGui files into a library (.a) in code warrior ?
- is there another way to use eGui with c++ project ?
2/
I found some tutorials to port the Freescale compiler to the GCC compiler (changing the toolchain in CW from ARM toolchain to ARM Ltd Windows GCC), but I would like to do the opposite, so my questions are :
- What are the differences between the Freescale compiler and GCC, does one of them is more optimized ?
- Is there any tutorial available to explain step by step how to change from GCC to the Freescale compiler ?
Thank you in advance for your help,
Camille
353件の閲覧回数
trytohelp
Hi Camille,
In addition to Erich answer I recommend you to have a to the thread:
      Re: What is the differences between Freescale and GNU compiler?
Pascal Irrle
353件の閲覧回数
BlackNight
Hi Camille,
there is an option to create a library in the new bareboard project wizard of CodeWarrior 10.6:
See as well Creating and using Libraries with ARM gcc and Eclipse | MCU on Eclipse
I hope this helps,
Erich
