boot loader using data flash instead of program flash
496 次查看
barbercolman
The boot loader examples we have seen use the program flash not the data flash area. We know we need to set up the linker file to use the FlexNVM as program space. Not sure where to go from there. Does anyone have a working bootloader that users the FlexNVM as program flash? We are using the MC56F844X DSP.
338 次查看
TICS_Fiona
Hello DALE
FlexNVM is not used in our bootloader project for 56F84789. Below is extracted from the map file of this project:
# Memory map:
  v_addr   p_addr size     name
  00000000 00000000 000000DE .interrupt_vectors .pIntvectorBoot
  00000200 00000200 00000008 .FlashConfig .pFlashConfig
  00000208 00000208 0001F1F5            .ppFlash
  0001F3FD 0001F3FD 00000003 .delay_time .DelayT
  0001F400 0001F400 0000078A .ApplicationCode .pFlash
  00000000 00000000 0000048D .data_in_x_ram_bss .xRAM_bss
  0001FBE1 00000800 0000004C .data_in_p_flash_ROM .xRAM_data
  00000A00 00000A00 00000200 .data_in_x_ram .xRAM
  0001FB8A 00062000 00000057 .prog_in_p_flash_ROM .pRAM_code
00002000 00002000 00002000            .xRAM_code
The bootloader code locates from 0001F400 in primary program.  It seems that we are not using the same project.  Please download from this link:
http://cache.nxp.com/files/microcontrollers/doc/app_note/AN4759SW.zip
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
