artifact name
artifact name
702 次查看
stefanomanca
Hi, can I set the artifact name from code source, using for example a directive?Thanks.
564 次查看
TICS_Fiona
Hello stefano
User can use the Build Artifacts properties tab to specify build artifact information, such as the type and name, that gets built by the selected build configuration.
Can it meet your request? If not, could you please give more details of the purpose to set artifact name from code source? Thank you very much!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
564 次查看
stefanomanca
Hi, I need change the artifac name by source code because of changing the elf name for diferent flashing product name.
For example
//#define PN1 1//#define PN2 2
#define PRODUCT_NAME PN2
#if PRODUCT_NAME==PN1 #define DELAY 100
#elif PRODUCT_NAME==PN2 #define DELAY 200
#endif
I wish when I build that elf name to be PN2
thank you.
Messaggio originale----
Da: "TICS_Fiona" <admin@community.freescale.com>
Data: 01/06/2016 10.23
A: "stefano manca"<smec@inwind.it>
Ogg: Re: - artifact name
a
body {
font-family: Helvetica, Arial, sans-serif;
-webkit-text-size-adjust: 100%;
h1, h2, h3, h4, h5, h6, p, hr {
-webkit-margin-before: 0;
-webkit-margin-after: 0;
-webkit-margin-start: 0;
-webkit-margin-end: 0;
.button td {
background-image: -moz-linear-gradient(top, #75B7E3 0%, #5498D6 50%, #408BD0 51%, #387AC8 100%) !important;
background-image: -webkit-gradient(linear, left top, left bottom, color-stop(0%,#75B7E3), color-stop(50%,#5498D6), color-stop(51%,#408BD0), color-stop(100%,#387AC8)) !important;
-webkit-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !important;
-moz-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !important;
NXP Community
artifact name
reply from Xin Kuang in CodeWarrior Development Tools - View the full discussion
Hello stefano
Best Regards
Fiona Kuang
