When I change a Floating point number to unsigned integer and compile the source code, the compiler would tell me some error as below
Link Error : L1822 : Symbol _FUFLOAT in file C:\...........................\......c.o is undefined.
Link Error : L1822 : Symbol _FMUL in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FADD in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FDIV in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FUTRUNC in file C:\.........................................c.o is undefined.
Below is my source code.
#include <stdlib.h>
#include <stdio.h>
#include <float.h>
#include <hidef.h>
uint16_t TempBuffer;
float TempBufferF;
int main() {
TempBuffer = (uint16_t) TempBufferF;
return 0;
I already put the header file "hidef.h". It seems cannot help.
Please help.
已解决! 转到解答。
Hi Henry,
Thanks for your response.
Your change from Ansib.lib to Ansibf.lib is correct, you need to use ansibf.lib rather than ansib.lib to enable floating point support.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Hi Henry,
Hope it helps!
Carlos Mendoza
