Type changing problem (Float to Int)
1,977 次查看
monstor
When I change a Floating point number to unsigned integer and compile the source code, the compiler would tell me some error as below
Link Error : L1822 : Symbol _FUFLOAT in file C:\...........................\......c.o is undefined.
Link Error : L1822 : Symbol _FMUL in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FADD in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FDIV in file C:\.........................................c.o is undefined.
Link Error : L1822 : Symbol _FUTRUNC in file C:\.........................................c.o is undefined.
Below is my source code.
#include <stdlib.h>
#include <stdio.h>
#include <float.h>
#include <hidef.h>
uint16_t   TempBuffer;
float           TempBufferF;
int main() {
     TempBuffer = (uint16_t) TempBufferF;
      return 0;
I already put the header file "hidef.h". It seems cannot help.
Please help.
标记 (1)
1,734 次查看
Carlos_Mendoza
Hi Henry,
Thanks for your response.
Your change from Ansib.lib to Ansibf.lib is correct, you need to use ansibf.lib rather than ansib.lib to enable floating point support.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
1,734 次查看
Carlos_Mendoza
Hi Henry,
Could you tell us which MCU are you using?
Carlos Mendoza
1,734 次查看
monstor
Dear Carlos,
I am using S12DP512 now. I just change the library from Ansib.lib to
Ansibf.lib. It seems can work. Is this method correct?
Henry
1,735 次查看
Carlos_Mendoza
Hi Henry,
Hope it helps!
Carlos Mendoza
