P3041DS Hydra Problem
630件の閲覧回数
dmitrshard
Hello!
I try to launch helloWorld project through CodeWarrior Tap (Download debug configuration) and have problem. See screenshot. What i need to avoid this error?
Original Attachment has been moved to: dada.zip
タグ(1)
459件の閲覧回数
yipingwang
Hello Dmitr Shard,
There is no argument "CCM/BPTRAR" in the default CW initialization file, and I didn't encounter this problem when initialize the target with the default CW initialization file.
So would you please provide your CW initialization file which you specified from Run->Debug Configurations-><project>-core00_RAM_p3041_Download->Edit->Edit->Initialization->Initialize target script?
And which version CodeWarrior do you use?
Yiping
459件の閲覧回数
addiyi
Did you use bareboard project generated by wizard? Did you select P3041DSHydra as board? Also, please check the init file used.
Adrian
