Is their any other hardware that I can use to do flash programming and hardware Dianosigic with MPC5200 PowerPC e300 Core Integrated Processor (400MHz)?
I had tried with Codewarrior Tap CWH-CTP-BASE-HE but the CodeWarrior doesn't seems to connect to my target board.
I tried using CWH-UTP-PPCD-HE and i can perform flash programming as well as hardware Dianosigic.
Thanks.
Evan
Hello Evan
The part number of USBTAP that support MPC5200 is CWH-UTP-PPCC-HE. However it is not manufactured now.
Its replacement is CWH-CTP-BASE-HE.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW_TAP
However if you are using CodeWarrior for MobileGT v9.2, you need install CCS update. For details, please review this document:
http://cache.freescale.com/files/32bit/doc/app_note/AN4780.pdf
CodeWarrior for MobileGT v9.2 also supports Abatron BDM-2000. In CodeWarrior's Connection select menu, the connection name for it is Abatron Serial and Abatron TCP/IP.
Hope it helps!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
Hello Evan
The latest CodeWarrior version that supports MPC5200 is v9.2:
CodeWarrior Development Tools for mobileGT|NXP
MPC5200 is an old product, and we have not updated its CodeWarrior for many years.
Best Regards
Fiona Kuang
Hello Evan
The part number was included in my first reply.
Best Regards
Fiona Kuang
Hi Fiona,
CWH-UTP-PPCC-HE is the only Codewarrior USB TAP that can support MPC5200? There’s no other version or previous version that can support MPC5200?
And CWH-CTP-BASE-HE is the only replacement that we can use with MPC5200?
Currently we could not use CWH-CTP-BASE-HE to test out our target board.
We tried with CWH-UTP-PPCC-HE and can be tested.
But we could not get any CWH-UTP-PPCC-HE as it is not manufactured now.
We would like to know the list of Codewarrior USB TAP that can support MPC5200 so that we can have more option to source for.
Thanks.
Evan
