D Flash data is not getting updated correctly on mc9s12xep100 after power on.
542 次查看
salmanshaikh
I am using mc9s12xep100 board and 'IEE1.c' and 'IEE1.h' to update some values in D flash.
I am using following code to read a byte from D Flash, if value is less than 50, I set value to 1,
otherwise i increment the value by 1.
But I always see the value as 1.
When I am in debug mode, this code works correctly. When in run mode I face the above problem.
uint16_t RetVal=0;
uint8_T NewData =0;
RetVal = IEE1_GetByte((IEE1_TAddress)(0x100D00), &NewData);
if(NewData > 50) {
NewData = 1; // If previous value greater than 50, set value to 1
RetVal = IEE1_SetByte((IEE1_TAddress)(0x100D00),NewData);
} else {
NewData++; // If previous value less than 50 increment value by 1
标记 (1)
451 次查看
ZhangJennie
Hi Salman,
To investigate your problem correctly and efficiently, please provide us the follows:
1.    your CW version:
  Start the IDE and click on Help | About Freescale CodeWarrior. Click on Installed Products.Save all info displayed into a txt file and upload it here.
2.    send the entire sample code folder(include mcp, prm,c...) in zip format to me.if your project is confidential, please create a new demo project and isolate the problem a demo code to me so that i can test it on my side directly.
3.      error screenshot.
I will check your problem based on your feedback. Thanks.
Jennie Zhang
