CodeWarrior Fail
CodeWarrior Fail
555 次查看
peterzheng
I was using codewarrior for some bareboard project. It was working fine until just now. Now when I open codewarrior, when I click on the Debug Configuration, or Run Configuration. Nothing shows. I didn't make any changes. I tried to restart my system. restart the CodeWarrior. But it didn't work.
Should I reinstall the CodeWarrior? If so, how can I preserve all my projects and profiling results?
Peter
标记 (1)
488 次查看
TICS_Fiona
Are you logging on Windows as Administrator?  Are you using Floating license?
Please delete .metadata folder of workspace of CW 10.x.
Then reopen the project in CodeWarrior, and click on 'Project' menu-> Clean to remove the old object file, and then rebuild the project. Is the problem fixed?
If not, please create a new bareboard project and test again.
Fiona Kuang
Technical Information & Commercial Support
