I just followed through installation guide for Code Warrior v10.3 for etpu.
I am currently having this kind of error.
I tried to remove .metadata file from my workspace and tried to open code warrior again but this error keeps popping up.
I set all the installation settings to default.
What might be the problem?
Hello Stanish,
I am also facing similar error with Code warrior 11.1 on windows 11 OS.
I have installed CW11.1 in a default folder (C:/Freescale/CW MCU v11.1) which has admin access rights.
As some blogs suggested, I have tried to install Visual C++ 2008 SP1 but it is no longer supported by Microsoft and also Windows11 doesn't support Visual C++ 2008 SP1.
Hence I have installed latest version of Visual C++.
But I am still getting the same error.
Sending you the diagnostic folder and the error Screenshot.
I am facing same problem but for CW11.1. I have windows 11.
is it resolved at your side?
