I am working with P4080DS and Code warrior 10.5. I am trying to debug a linux application.
As per the code warrior documentation, I need to run AppTRK.elf on the target Linux system but it doesn't describe on how to generate the AppTRK.elf file.
Please assist me on generating the same.
Rahul
已解决! 转到解答。
Building apptrk for p4080ds works fine for me. Attached you can find exported_flags script that I used. Please modify the path and source this script before build the apptrk.
Adrian
There are two ways to generated the apptrk,elf.
1. Build the apptrk sources provided in CodeWarrior (Freescale\CW_PA_v10.5.0\PA\PA_Tools\AppTRK\)
2. If you use SDK to build your linux images, add apptrk in build recipe.
Adrian
Hi Adrian,
Thanks for the prompt reply.
I tried method 1 before posting the question itself. But I am getting errors when I am trying to use MAKE for the source present at:
Is there something that I am missing? Any specific step that needs to be performed for build AppTRK source code?
Rahul
I don't think the error is related to toolchain. Please see the following error log.
I followed the steps in Freescale\CW_PA_v10.5.0\PA\PA_Tools\AppTRK\appTRK\INSTALL.
The configuration step is successful but MAKE is throwing errors.
Hi Adrian,
I tried the same steps as you mentioned over and over again but I kept getting errors in the source files.
But after removing the apptrk folder and regenerating it from the back up .tar file, I was able to generate the AppTRK.elf file with the same sequence I was trying earlier. Not sure what the problem really was.
Anyways, the problem is solved. Thank you very very much for your support.
Rahul
