- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I am working with P4080DS and Code warrior 10.5. I am trying to debug a linux application.
As per the code warrior documentation, I need to run AppTRK.elf on the target Linux system but it doesn't describe on how to generate the AppTRK.elf file.
Please assist me on generating the same.
Rahul
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Building apptrk for p4080ds works fine for me. Attached you can find exported_flags script that I used. Please modify the path and source this script before build the apptrk.
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There are two ways to generated the apptrk,elf.
1. Build the apptrk sources provided in CodeWarrior (Freescale\CW_PA_v10.5.0\PA\PA_Tools\AppTRK\)
2. If you use SDK to build your linux images, add apptrk in build recipe.
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Adrian,
Thanks for the prompt reply.
I tried method 1 before posting the question itself. But I am getting errors when I am trying to use MAKE for the source present at:
Is there something that I am missing? Any specific step that needs to be performed for build AppTRK source code?
Rahul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Did you use correct cross toolchain when building apptrk? Could you share the errors you get when building?
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I don't think the error is related to toolchain. Please see the following error log.
I followed the steps in Freescale\CW_PA_v10.5.0\PA\PA_Tools\AppTRK\appTRK\INSTALL.
The configuration step is successful but MAKE is throwing errors.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Adrian,
Can you please assist me with the issue?
Rahul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Rahul,
Did you use ./configure? Could you share configure command? Did you build libelf before building apptrk?
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As I mentioned the configuration step was correct. The ./configure did not throw any errors. And yes libelf was built.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Adrian,
Please see the snapshot for ./configure step.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Adrian,
I tried the same steps as you mentioned over and over again but I kept getting errors in the source files.
But after removing the apptrk folder and regenerating it from the back up .tar file, I was able to generate the AppTRK.elf file with the same sequence I was trying earlier. Not sure what the problem really was.
Anyways, the problem is solved. Thank you very very much for your support.
Rahul
