MC56F8322 SCI Bootloader with Codewarrior Ver 5.2.1279
1,866件の閲覧回数
cwr_whitehead
I'm looking for the serial (SCI) bootloader code for the MC56F8322, that will work in Codewarrior ver 5.2.1279. Does anyone know where it can be found?
I need to change it to program the flash using SCI0 instead of SCI1.
Assuming I get and modify the code, do I just use Codewarrior Debug (JTAG) to program the boot flash?
タグ(1)
533件の閲覧回数
cwr_whitehead
I've downloaded Codewarrior ver 8 and updated to Ver 8.1
Found the Bootloader code, modified and built fine. My problem now is that whenever I try to use Codewarrior debug I get the following error.
CCS ProtocolPlugin : CCS: Command Convertor not present.
Can anyone help.
