DSP56F801 flash_over_jtag and XP
2,530件の閲覧回数
cwr_whitehead
I'm trying to use the latest version of the 'flash_over_jtag' application (Epsilon 0.7) to program two daisy chained DSP56F801's. The application ran on PC's using Window 2000. We have now upgraded to XP and the application will no longer work.
Whenever I try to run the application, I get the following error:
I/O port driver not installed
Installing...
I/O port driver cannot be started
Unable to access to I/O driver
Thanks in advance (hopefully).
Message Edited by CrasyCat on 2007-04-13 10:44 AM
タグ(1)
2 返答(返信)
738件の閲覧回数
DanielM
do you have admin rights on your computer? Is it 32 or 64 bit version of XP (the program was not tested on 64-bit XP at all).
738件の閲覧回数
cwr_whitehead
Hi Daniel,
I've solved the problem. Somehow the zlportio.sys file had been corrupted. I downloaded a new copy and replaced it, now everything works. Obvious really.
Thanks for the help.
