Classic - How to use HCS12 on Eclipse?
-build and debug a CodeWarrior project-
Valid for some Classic versions - CW for MCU V6.x, CW for HC12 V5.1, etc ...
Configuration used:
Software
Native installation Win 7 Enterprise 64 bit
CodeWarrior HC12 v5.1
CodeWarrior for MCU V10.6.4 (Updates 5&6)
Hardware
S12XDT512
Multilink Universal rev B
Introduction
Since 2010 we started to move our development tool chains from Classic IDE to Eclipse.
However we continue to use classic tools for some products as CW for HC12 V5.x for HCs12 devices.
The advantage of HC12 is that all features are used in command line in the IDE.
So we can use another IDE than CodeWarrior IDE as Eclipse for instance.
This doc will show you how to:
Attached you will find:
More references/information can be found at:
https://community.freescale.com/message/364157#364157
http://mcuoneclipse.com/2012/02/13/make-my-make-with-eclipse-and-mcu10/
NOTE:
For Classic versions using integrated debugger, only the build operation can be done under Eclipse.
When the debugger is not available as standalone version there is no way to define an External Tools in Eclipse.
Phase 1: Create a Project under Eclipse based on a HC12 project
File ¦ New ¦ Other …
Enable Show All Wizards and select the C Project (which is otherwise hidden), pressing Next.
Click OK
Specify the project name, select an Empty Project under Makefile project with — Other Toolchain — and press Finish:
Now I have an empty project
Using Project ¦ Properties specify my Build Command:
${system:ECLIPSE_HOME}/../gnu/bin/mingw32-make -j6
Phase 2: Build the project using HC12 build tools chain with makefile
By this way you will have the options and other paths used for compiler and linker to build the project.
We can use these information to create the makefile.
An empty makefile is created.
You need to create your makefile according to your project.
For more details we recommend to refer to the link:
This is the makefile created for this example.
The makefile created contains 2 operations:
all -> build the project and generate Srecord files
clean -> remove all generated files
for all and clean operations with the "Make Target" under Window ¦ show View
Now I can build the project using HC12 v5.1 tools (compiler/Linker) under Eclipse project
Phase 3: Add External debugger to debug hc12 application
HC12 V5.1 is using an external debugger named Hiwave.
This tool is using a config file named .ini.
To use HiWave under Eclipse project, we need to define it as external Debugger.
By the Run menu click on External Tools ¦ External Tools Configuration…
Run will launch the Debugger and the project.ini file will be generated in the \Bin folder
You can edit the ini file and use the info provided in the .ini file of HC12 V5.1 project
To use these settings, add the Arguments:
project.abs -w -Target=icd12 -Prod=project.ini
Now the debugger is launched and application loaded on board with Multilink Interface.
I try to follow the tutorial, but the attached files are not available.
Could you please send me the makefile?
Thanks!
