- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hello everybody.
First of all, i need to admit that I am not a native SW engineer, therefore it might be possible I use the wrong technical vocabulary in my question.
We use CW5.2 for our projects with HCS12X-MCUs with "standard suite" license.
Is it possible to run the compiler for HCS12 and XGATE projects from a command line or batch script? I mean: is it possible to somehow "automate" the whole process of generating the binary files (.s19 and .abs) files from the source code files (.c and .h) for a codewarrior project without manually opening CW and manually clicking the "build" button?
Thank you a lot and best regards,
Alex
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
OK, I think I was able to find an answer myself in the meantime.
I found the following document which describes the command line interface:
http://www.nxp.com/files/soft_dev_tools/doc/user_guide/IDEAUTOUG.pdf
I was able to create my own "build command" which, at least as long as there are no errors during compile, generates the appropriate binary files! :-)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
