CW12 v3.1 - Getting Build Errors for Supplied Beans
almcneil
I just started at a new position. I had to install CW for HCS12 (VW12 v3.1) After initially having a licensing issue resolve by Freescale support team, I then went to build 2 different projects. Both builds failed and I noticed all 4 errors had to do with the supplied beans. I have attached a screenshot of one of the build report. I think I have to configure something for the beans to get this to all work. If someone can review the report and tell me where to start I would appreciate it.
Andy McNeil | Systems Engineer
Spotwave Wireless Inc.
Kavveri Telecom Products Limited
  1. P.O. Box 550
500 Van Buren Street
Kemptville, ON K0G 1J0
CANADA
T 613.591.1662 ext. 3336
F 613.258.7418
E andy.mcneil@kaveritelecoms.com
trytohelp
Hi Andy,
According the info/errors, there are problems with the beans.
you must check the beans to have more info about the problem.
the wrong/mistake will be "highlighted/marked" in red in the bean configuration.
Click at Processor Expert Tab under the Project.
Pascal
