Optimize Power with Dynamic Voltage Scaling using PVT Sensor on i.MX RT500
kyledando
Are you looking for ways to increase the battery life of your design that includes the i.MX RT500?
This new Application Software Pack introduces a Dynamic Voltage Scaling solution based on the PVT Sensor included in the RT500.  The Application Software Pack includes materials that will help you quickly evaluate if this can work in your end application.
Use this software forum to get answers to your technical questions: App SW Pack Forum
Visit nxp.com/dvs-pvt-sensor for complete details on the Application Software Pack.
Be sure to watch the video walkthrough: App SW Pack Training Page - DVS PVT Sensor
Below are diagrams that help show the fundamental concepts of the solution.
The 1st block diagram shows the RT500 using the PVT and Temp sensors to adjust the VDDCORE voltage supplied by an external NXP PMIC.  The software monitors the performance of the core logic, adjusting the voltage when necessary.
The 2nd diagram shows the voltage being scaled up or down based on the temperature level.
956772-CS_Application SW pack_DVS_BD_Temperature Image_v1nm_NoTitle_NoBackground_HR.png
iMXRT500
Tags (4)
