MC9S08LG32 LCD Module Voltage?
643 次查看
sandeepnaik
I am using MC9S08LG32 (LQFP-80 package) with inbuilt LCD Module.
I am operating my core and other peripherals at 3.3 VDC.
Can I still operate my LCD Module from 5 VDC power-rail without damaging the controller.
466 次查看
philip_drake
Hello sandeepnaik,
The LG32 has an integrated LCD driver that can supply LCD waveforms for 5 V glass.  You can use the on-chip charge pump to create the 5V source needed to drive the LCD when operating the MCU at 3.3V.
The only time you should connect VLL3 to 5 V is when the MCU voltage is set at 5 V.
The externally supplied voltages MUST NOT EXCEED VDD :smileysad:.
Check out the reference manual, LCD section
Table 9-19. LCD Power Supply Options.
http://cache.freescale.com/files/microcontrollers/doc/ref_manual/MC9S08LG32RM.pdf?fpsp=1
Philip :smileyhappy:
