Inline Assembly Troubles (Such a Noob Problem)
3,439件の閲覧回数
mjcoury
I am having some trouble with my inline assmebly. to preface everthing, this is my routine to read memory out to the serial port
void ReadRamOut(word iMemory, int iByte) {
int i = 0;
char *memory_ptr;
memory_ptr = (char*)iMemory;
for( i=0; i
SCIStartTransmit(*(memory_ptr+i));
} // end for
} // end ReadRamOut
Here is the code to write to flash
DisableInterrupts
for( i=0; i
ctemp = gu8SCIData[i];
asm{
LDA ctemp
STA memory_ptr
WriteFlash();
memory_ptr++;
} // end for loop
iMode = 0x00;
gu8SCIIndex = 0;
EnableInterrupts
I show the ReadRamOut routine because that method of pointing to a memory location has worked for me... so I assumed it would work again for the inline assembly....
Now assume iMemory = 0x1600. instead of writing ctemp to the memory location 0x1600 it writes over the 0x1600 with the contents of ctemp. I have tried a few different combinations of iMemory and memory_ptr to get this to work.. Any Ideas?
Message Edited by mjcoury on 2006-08-01 08:58 AM
3 返答(返信)
637件の閲覧回数
rhinoceroshead
If you just want to transfer the contents of gu8SCIData[i] into the location pointed to by memory_ptr, then you can just do this:
*memory_ptr = gu8SCIData[i];
There is really no need to fuss with the inline assembly - but the reason it might be failing could be that you are erasing the contents of the accumulator when they are needed.  Try this assembly instead:
PSHA
LDA ctemp
STA memory_ptr
PULA
What is in the WriteFlash() function?  Do you know that works?
637件の閲覧回数
mjcoury
void WriteFlash(void) {
byte temp = 0x00;
if ((FSTAT & 0x10) != 0) {
FSTAT |= 0x30;
asm {
//LDA #$CC
//STA $1600
LDA #$20
STA FCMD
LDA #$80
STA FSTAT
NOP
NOP
NOP
NOP
WFLOOP:
LDA FSTAT
LSLA
BPL WFLOOP
} // end WriteFlash
Yes, I know it works.. if i use
asm{
LCD #$CC
STA $1600
WriteFlash()
the value of 0xCC will be written to location 0x1600
Message Edited by mjcoury on 2006-08-01 09:58 AM
637件の閲覧回数
CompilerGuru
as rhinoceroshead already pointed out, such simple assignments can be made easely in C, no need for HLI.
The HLI assembly instruction "STA memory_ptr" clearly stores the content of A into the high byte of the local variable memory_ptr. If you want to store to the place were memory_ptr points to, you have to load it into H/X, and then do a STA 0,X. Just using C is much simpler tough:
*memory_ptr= ctemp;
