EEPROM version of 68HC705
896 次查看
Chilakaluri
Is there any EEPROM version of 68HC705 available?
5 回复数
495 次查看
ZhangJennie
Freescale doesn't have developement tool for  68HC705. we recommend you use tool from P&E and Cosmic for the detail information, please see http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=68HC705C8A&fpsp=1&tab=Design_Tools_Ta... the tools are listed under " IDE - Debug, Compile and Build Tools (2)"
495 次查看
pavel_sadek
I do not think so, that device is really obsolete
I would suggest to check some of suitable S08 devices instead.
Pavel
495 次查看
Chilakaluri
Hi Pavel,
Thank you for your response. We have a product with 68HC705 and I need to make some minor changes to software. Because I do not have the development tools(debugger/emulator) I am not able to test the software efficiently as 68HC05 has only OTPROM.
Are there any development tools still available for this IC?
Thank you for your time.
Mahendra
495 次查看
Wlodek_D_
Senior Contributor II
Hello Mahendra,
What is full Part Number of your "68HC705" MCU? This info will help to find the right development tool and its current availability status.
Wlodek_D.
495 次查看
ZhangJennie
