I believe that the problem was on the installation, you do not have installed the S08 family, the easier solution is to reinstall Codewarrior and when you are installing it you need to select the S08 devices.
I hope this will help you
Hi Vicente,
Thanks for your reply.
This is my CW version page
And this is the devices select interface when new a project, there is no HCS08SG Familly.
And I and can't search any devices when input MC9S0.
Is there any update packages should I install?
Sarah
