Setup MQX with PE on K20
Question asked by Hans-Friedrich Gasser on Nov 14, 2011
Latest reply on Nov 30, 2011 by Hans-Friedrich Gasser
I have some Problems to set up a new project in CW 10.1 with MQX 3.7 and PE for my self designed Kinetis K20 board.
I tried to setup a new PE projekt by myself and add the component MQX, but get several files not found erros.
I also tried to take the Kwikstik MQX+PE sample project and tried to change the CPU component, but got errors because it seems to be not enough only to change the CPU in the PE component. (Kwikstik has K40 CPU)
Is there any "how to" for setting up an MQX + PE project or a sample Project for K20 (100pin) CPU?
