breakpoints won't set
Question asked by Nicholas Geoca on Nov 13, 2011
Latest reply on Aug 6, 2015 by Dorde Stojicevic
I'm using CodeWarrior 10.1.1 for the P1010RDB and break points won't set. The two following errors are as follows:
1: Breakpoint when stopping at main under debug settings.
Error stopping at main.
Reason: Target request failed: Failed to set breakpoint.
Continue?
2: Info under the Breakpoints tab when setting one manually.
File was not found in symbolics information., Unresolved breakpoint
These seem to have occured when tranisitoning to static libraries instead of shared libraries. Any help in getting it to work is appreciated. Thanks.
Nick
