gilles buloz
Priorities and RTCS server startup failure / unexpected application crash
Discussion created by gilles buloz on Nov 11, 2011
If you are using MQX 3.7 and have failures when trying to start RTCS or an RTCS server (Telnet, HTTP, SNMP, ...) : RTCS_create(), TELNETSRV_init(), httpd_server_run(), SNMP_init(), ... returning a failed status.
Also if you use an older release of MQX but have unexpected application crashes when using RTCS
Maybe you are concerned (like me) by the problem decribed in the following post
Missing info about _task_create() and priority issues
