How to replace Memory operand constraint "m" in Codewarrior for HCS12 controller.
"m" (*((unsigned char *)&log_tooth+1)), \ // byte 3:**2**:1:0
"m" (*((unsigned int *)&log_tooth+1)), \ // bytes 3:2:**1**:**0**
"m" (synch), \
"m" (flagbyte1) ;
While compiling the above code in codewarrior i am getting the below compiler error.
Error : C12070 Identifier expected.
As Memory operand constraint is not supported in codewarrior, can someone suggest the solution for the above problem.
Nagarjuna Reddy
