Kwikstik rev 5 + CodeWarrior: patch needed, any experience?
Question asked by Michele Marchetti on Oct 28, 2011
Latest reply on Nov 4, 2011 by Michele Marchetti
Dear all,
I finally got a Kwikstikc rev 5 so that I can start use the SD card support (which was broken by design in rev 4).
I am using CodeWarrior 10.1.
While attempting to access to esdhc I get the following error:
    com_handle = fopen("esdhc:", NULL);
    if( !com_handle ) {
        printf("DBG: Opening ESDHC device failed, is ESDHC controller enabled in MQX?");
Problem is that I have to enable ESDHC in bsp, but the
init_bsp.c
file retreives me the following error:
#error This modul unsupported with Kiwkstik Board.Please disable BSPCFG_ENABLE_ESDHC to 0 in user_config.h
Is there anyway around this?
Did anyone used the rev 5 of Kwikstik with codeWarrior?
I asked to Freescale for a patch for MQX and Kwikstik rev 5, which should prevent that re-compiling error of bsp to happen, but they said there is none available.
Any hint?
thanks,
Mik
