xinzhou tang
MCF52259 as USB device
Discussion created by xinzhou tang on Oct 27, 2011
Latest reply on Oct 27, 2011 by Mark Butcher
Hello ,
I am now using MCF52259 as an USB device .  It's the first time to use usb peripheral .I am a little confused about the meaning of  tok_dne bit .
If  this bit is set only after receiving a token packet ?
For example if it's an out token ,  what will happen after receiving a data packet from the host  ?  A bit will be set to indicate the receiving of a data packet ?
Also , if the device wants to send a status packet . What will the device do ?
thanks a lot .
tangxinzhou@gmail.com
