Hi,everyone!
I'm using the MC9S12XEP100.
When I debug the codes, some parts can only be dedugged with single steps. And I set some breakpoints. The codes don't run to the breakpoint. I want the reason!
Thanks for your help!
Make sure you have checked in debugger
HC12MultilinkCyclonePro->Setup...->Debug options->Disable maskable ISR's when stepping.
Kef, I'm sorry for replying you so late. It's all because of errors in codes. I've solved the problem. Thank you very much.
ustcsnaker
