Hello!
I am using Metroworks CodeWarrior 5.6 IDE for DSP56800E cpu. I want to start creating unit tests for my software and I want to build some of it for the Windows PC and use Check (or some other testing framework) to test the code.
I cannot find anything about pre-build commands to invoke the IDE to run my commands. Is there any possibility to do so in CW 5.6?
Check out Chapter 3, "Using Build Tools on the Command Line", in the 56800x Build Tools Reference manual. This manual is an Acrobat file named 56800x_Build_Tools_Reference.pdf, and the file should be located in the Help folder of your CodeWarrior installation folder.
---Tom
