claudia herrera
atoi function for a string array
Discussion created by claudia herrera on Oct 1, 2011
Latest reply on Oct 19, 2011 by bigmac
I´m working on a calculator but my atoi function isn´t working, its just converting the first digit as I enter it to my array. Any ideas ?
#include <hidef.h>      // for EnableInterrupts macro
#include "derivative.h" // include peripheral declarations
#include "lcd.h"        // lcd utility functions
#include <stdlib.h>
//#include <extras_stdlib.h>
char texto[5];
char keypressed,noper;
char nBuffer[6];
int  a,b,tst,result=0;
char keyPadMatrix[13] =
    '1','2','3',
    '4','5','6',
    '7','8','9',
    '*','0','#',
    0x00
void main(void) {
  char i;
  LCDinit();
   //MCU_init(); /* call Device Initialization */
  /* ### Init_GPIO init code */
  /* PTFDD: PTFDD3=1,PTFDD2=1,PTFDD1=1,PTFDD0=1 */
  PTADD |= (unsigned char)0x0F;
  /* PTBPE: PTBPE7=1,PTBPE6=1,PTBPE5=1,PTBPE4=1 */
  PTCPE |= (unsigned char)0xF0;
  /* PTBDD: PTBDD7=0,PTBDD6=0,PTBDD5=0,PTBDD4=0 */
  PTCDD &= (unsigned char)~0x00;
  /* include your code here */
  // inicializo mi buffer
  nBuffer[0] = ' ';
  nBuffer[1] = ' ';
  nBuffer[2] = ' ';
  nBuffer[3] = ' ';
  nBuffer[4] = ' ';
  nBuffer[5] = 0;  /*AQUI*/
  for(;:smileywink: {   //ciclo infinito
//* este IF solo ocurre cuando se presiona *, basicamente es un clr :smileyhappy: borra el array, las variables y el display */
    if (keypressed == '*'){   //borrar
      LCDClearScreen();
      nBuffer[0] = ' ';
      nBuffer[1] = ' ';
      nBuffer[2] = ' ';
      nBuffer[3] = ' ';
      nBuffer[4] = ' ';
      a = 0;
      b = 0;
      result = 0;
    keypressed = ScanKeyMatrix();
    if (keypressed != 0x00){
        for (i = 0; i < 4; i++){
          nBuffer[i] = nBuffer[i+1];
     nBuffer[4] = keypressed;
     //a = atoi(nBuffer);  //capturo el valor del buffer = al valor en pantalla
            LCDClearScreen();
            LCDputchar(nBuffer[0]);
            LCDputchar(nBuffer[1]);
            LCDputchar(nBuffer[2]);
            LCDputchar(nBuffer[3]);
            LCDputchar(nBuffer[4]);
    //aqui debo revisar si alguna operacion matematica ha sido escogida
/*Si se presiona push button este realiza una operación según el Case NOPER*/
    if (!(PTAD_PTAD4)){
      LCDClearScreen();   //limpio pantalla
      tst = 1;
      noper = 1;   //suma
      nBuffer[0] = ' ';                //
      nBuffer[1] = ' ';                //* el buffer almacena los teclasos de forma FIFO son 5 posiciones porque 16 bits = $FF = 65535 = 5 numeros */
      nBuffer[2] = ' ';
      nBuffer[3] = ' ';
      nBuffer[4] = ' ';
      while ( !(PTAD_PTAD4) ){
