Profiling In Code Warrior Power  Architecture  8.8
NeenaB
Im trying to do profiling for the code ported to MPC 8540 e500v1 core in Code Warrior Power  Architecture  8.8 IDE .  Is it possible to do profiling  using the simulator for the following target ?
genuap
Unfortunately there aren't any built in profilers in CW8.
NeenaB
I tried the following way for profiling function func1(). The functions ProfilerInit() and ProfilerDump() returned zero which indicates dat they have worked successfully. But my problem is dat profilereport.mwp dat i finally gets generated is completely blank and does not contain any profile information. Could you please tell me why is it happening dis way...
int main()
          int i,n;
          long err;
          err = ProfilerInit(collectDetailed, bestTimeBase,1,1);
          if (!err)
                ProfilerClear();
          else
                printf("Profiler failed to initialize\n");
           ProfilerSetStatus(1);
           for(i=0;i<n;i++)
               func1();
           ProfilerSetStatus(0);
           err = ProfilerDump("profilereport");
          if (err != 0)
              printf(" Profiler failed to dump profiler information\n");
          else
              printf("Profile data written to file successfully\n");
          ProfilerClear();
          ProfilerTerm();
          return (0);
