I'm working with CW 10.1 and qe128 micro,
if I try to pass compiling option in a file writing:
-ArgFile"${ProjDirPath}/config.txt"
in
Project -> Properties ->
C/C++Build -> Setting ->
HCS08 Compiler -> General -> Other flags
I get following error:
Error #580 in '<filename>' while compiling file ''<filename>', procedure '...', please report to Freescale
Building just the single file the same error happens, but not for every file (some are compiled successfully)
any suggestion?
Hello
According to my understanding you have added the option -ArgFile to the Build configuration settings.
That means the option is used to build all source files in your project.
On the other hand you get the internal error only on a couple of source file (not all).
Am I right?
If this is the case some construct inside of your source file seems to generate the trouble.
I would recommend you to submit a service request for that.
Click here to submit a service request.
Make sure to attach a reproducible project and installed product information to the service request.
CrasyCat
