Anders Johansson
HCS08 uart and 7 bits+parity
Discussion created by Anders Johansson on Aug 17, 2011
Latest reply on Aug 18, 2011 by Anders Johansson
As far as I can tell from the datasheet and Processor Expert the HCS08(DZnnnn) cannot
be set to 7 bit characters+parity.
If this is not true, can someone please explain where I may have slipped in my thinking.
If true, is there a efficient way to find the parity of the 7 lsb's
apart from the obvious shift/test/count method? ( and then stuff it into bit 7)
Anders J
