Hi all,
I have a hardware design project, mainly running the open source IPPBX - Asterisk (www.asterisk.org), the customer was required to use MCF54451, but i am afraid that cpu has no enough performance for Asterisk decode/code.
So, if you have a M54451 EVB board on hand, could you please help me running following command and post output message here
in m54451 shell prompt
1. asterisk -cvvvvvvvvvvvvvvvvvgr
2. show translation
Uolli,
We have a partner that has helped to implement the Asterisk code on the 5445x family.
Have you contacted Arcturus Networks?
They should be able to demonstrate that it can be done and provide services if needed.
I did find that we still have the lab setup PPT on the web, maybe this might help.
-JWW
Hi JWW,
Thanks for your reply, i saw that ppt file, but i can not found any information about M54451 EVB board at their website .
Will try to contract them directly or who has such board on hands will be easy more
Thanks.
