MPC5125 LTIB - How to build the kernel for the BSP
JBaker
The attached pdf descibes the method in very brief form of how i used the MPC5121 LTIB as the basis for the MPC5125 LTIB. By adding the MPC5155 BSP to the MPC5121 LTIB and re-configuring the LTIB, you can end up with a compilable MPC5125 kernel.
I have used this to build the kernel on a Suse 11.3 virtual machine. It has been run sucessfully and I hope that this rough guide helps.
I would be interested in any comments or questions as these forums help me as much as anybody else.
James Baker
sandmanxyz
Hi James,
Thank you very much for all your hard work. We'll follow your document and try to build an image for our MPC5125-TWR target using the LTIB tool. We'll let you know how it went as soon as we can.
albfon
I tried use this manual for compile kernel for mpc5125twr usin ltib tool from MPC5121ADS but it has been unsucessfull.
I have several compilation errors.
Do you have got it?
Thank You
