Is there a MQX 3.7 for CW 7.1?
SVC2
It seems like MQX 3.7 supports only CW7.2
1)      The projects (mcp) files are not compatible.
2)      Even if I arrange the mcp files, I don’t think the code will compile since 7.2 is not backward compatible with 7.1
Is there a 7.1 version available?
S
petr_uhlir
No, the support for older CodeWarrior for ColdFire 7.1 was removed in MQX 3.6.0
Only backward compatibility is maintained. The projects are converted to new version
Hard to say, we have not generated and tested 7.1 projects.
Do you have any problems to switch to CW7.2?
petr_uhlir
CarlFST60L
Senior Contributor II
I have just been forced to update to CW10.1 over the last couple of days due to lack of support for 7.2. Mostly for the D4D demo's.
