K60 FlexCAN demo problem
Question asked by Mogens Svendsen on Jun 8, 2011
Latest reply on Jan 26, 2012 by Robert Ussery
I'm trying to run the FlexCAN demo on a Tower K60 board, with serial board. (MQX 3.7 and IAR EW-ARM 6.20)
It doesn't seem to work - data is apparently transmitted, but nothing is received. Also, I can't measure any activity on the CAN RX/TX pins in tower connector. I checked pin mux is ok. Also, I tried to fix for the e2583 errata, which seems to work.
// e2583
OSC_CR |= 0x01<<OSC_CR_ERCLKEN_SHIFT;
Any ideas? Can you successfully run the FlexCAN demo?
This is my output:
Data transmit: 155
FLEXCAN tx update message. result: 0x0
Data transmit: 156
Data transmit: 157
