Solved! Go to Solution.
the I2C example should work for you without any change. 24C02 has the same page size and the example doesn't access memory at addresses above 2 kB. Just check whether you have set the same HW address of the memory (A0=A1=A2=0), otherwise change I2C_EEPROM_ADDRESS in eeprom.h.
PetrM
PetrM
