Codewwario10 .1 SE -License problem
droga
Hello everyone
Recently installed the codewarrior 10.1 SE. everytime I try to compile an application or use codewarrior he asked to indicate the place where it installed the license, which in this case is not because it is a special version.
I spoke with support, but nothing was said about how to solve the problem.
if someone can help me how to solve this thank´s.
dominate606
Update:
I did not find the registry mentioned, but I added  the line
FLEXLM_BATCH= -add 1
 to the file {Install path}\CW MCU v10.1\eclipse\cwide-env. The Popup is gone!
Dominik
dominate606
Hi droga,
I had the same problem, the builder asks for a license every time it is invoked. You can just close the window (red x). Depending on the complexity of the code, this has to be done several times.
I read about a solution on towergeeks, but I could not find the mentioned registry key. Somewhere else I found that it would be fixed with some hotfix, can't remember where.
Hope it helps,
Dominik
