Please Help - USBDM - Target connection failure
Question asked by Jonathan Abbatiello on May 12, 2011
Latest reply on May 16, 2011 by Jonathan Abbatiello
Hello Friends!
I have received the following error message from Code warrior after I installed a set of sample code which lead me to believe that I had accidentally secured my uC. However, it seems that the code does not entail any lines that would cause this to happen. The error message I am receiving is detailed below:
"USBDM - Target connection failure
USBDM can't enable BDM made on the target. This may indicate that the device is secured. "
Does anyone have any ideas?? Thank you so much for you time, I greatly appreciate it!!!
